Guess my ET?
1969GTS340
Akron, NY
I'm finalizing my build for a local 1/8th track and would appreciate feedback on an estimated ET this car might be capible of?
Thanks in advance FABO members.
3200 lb ~ Demon
340 +.060 KB243 ~10-1
Lunati VooDoo hyd. .547/.568 234/242 @50 110/106 respectfully
Hughes EQ Magnum closed chamber heads, SS 2.02/1.66 w 1.6 rockers
Holley 750 DPDF / Airgap
Dougs headers
727 Manual valve body w/ Turbo Action 8" converter
742 Carrier w/ 4:88 on a spool.
9x29 slicks 15" centerlines.
6 cyl front supension.
Pinion snubber.
Fuel cell and Battery in the trunk.
Fiberglass hood, bumpers and seats.
6 point Comp Eng cage.
What you're gonna run on your first time out and what the combo is capable of are two different things. First time out, I'll guess 7.55. I would think at least low 7's are doable once you get the chassis dialed in. Either way, keep us posted?
