Hard to find Manual Adjusting Drum Brake lower spring
dibbons
La Paz, B.C.S., Mexico
If you have drum brakes with manual adjusters, these springs look correct that keep the star wheel from moving between adjustments (the rear of my '65 Formula S has 10" brakes with manual adjusters on the 8 3/4 rear end a previous owner installed).
That's because it wasn't done this way .These cars came with self adjusting brakes with a whole different set up,What you have looks like 1950's ford with that spring over the adjusting wheel.It works but you have to improvise because it's not a stock arangement and there is no such thing as the "correct" part that you can just order.
Odie, can you get a length on the spring? I may have one, if I do I'll send it to you for postage. Bill S.
Thanks, but I am re-using the old ones. Just posted this for anyone looking for 'em since they are not included in brake hardware kits. For the record, the coiled portion is about 2 inches while overall length is about 3 inches.
