[FOR SALE] Harley parts
6pkScamp
Brooksville, Fla.
I have a 103ci top end for sale. Heads, pistons, automatic compression releases and wiring harness for installation. All you need is to bore your 96ci cylinders. $350 plus ship. Parts are in central Fl. PM if interested
So no jugs? If not, what happened to them? Pistons ok? I have a friend who might be interested, but I wanna be sure of all that's included first. Thanks.
Have done several. The HD cylinders are beefy enough to handle the 3 3\4 to 3 7\8 bore change. HD cylinders need to be done with torque plates and gaskets as I've seen .003 when loaded. Not sure on the stock cr but 10.5 and some cams and a tuner to wake it up. Fair price for the heads though.
I purchased them to bump my bike up, but changed my mind. I don't know what the original owner did with the jugs. I can get you part #'s if you like and more specific pics. The heads have provision for compression release's. I picked up a set of new c/r's and a factory wiring harness to install on my 07 ultra.
A bore job, set of rings and gaskets and you'll have a 103
Thanks G.
