Header Size
70wayfarer
new zealand
last year i built a set of fenderwell headers for a 440 build. that turned into a 493 stroker as they do. any way the tubes are 1 7/8" and 3 1/2" collector. are they now to small for the 493. this is a street strip build, spinning to 7000 rpm. cheers
How long are the primaries? If they are under 32 inches long I'd run it. IMHO it need a 3.5 inch collector between 18-24 inches long. Don't know how you can get that with a FW header though.
my collector is 3.5" and 14" long with dump pipe and the longest primary is 28". ran my specs through that calculator and seems all is good.
I just ran my combo through that calculator. It shows the primary way too small and too long with a small collector.
Reminds me of carb math.
Big block , or small block ?? THIS was directed at yellow rose, I know the o.p. said 493-----------just trying to clear up my dumb question! LOL
Id run them for now its always something you can change down the road when looking for better ET's.
Big block Mopar’s love big headers and big carbs. If you build another set I would build them 2 1/8” - 2 1/4” primary about 32”-36” long tubes and 3 1/2” - 4” collector for the most power. This is if it’s a healthy 493.
We built a set of 2 3/8” primary 4 1/2” merge collector headers for my 572 and they made a huge difference. All the tubes are equal length also.
