Headliner bows '63 dart
You can make your own length is what changes in bow order. B-body info mainly.
68 Roadrunner, Satellite, GTX
FRONT
Brown 46.25"
Green 46.75"
Blue 46.75"
Red 48.00"
Black 53.00"
Black 55.50"
REAR
Measurements are tip-to-tip not following the curve.
On early a-bodies is
Front to back...
Brown
Green
Blue
Yellow
Violet
Black –on other b-bodys
1965 2DRHT
> Belvedere. The lengths are front to back: #1= 49 3/4" w/ pink paint
> on end #2= 50 3/4" w/ pink paint on end #3= 51
> 3/4" w/ blue paint on end #4= 52 1/4" w/ pink paint on
> end #5= 54 3/4" w/ pink paint on end and 90 degree
The bows won't work from a sedan to a hdtp.5 are needed on the hdtp and also they have more bow in them
It would be a tall order to make your own & get the curves correct. Strongly recommend you find a used set & save yourself great aggravation.
X2 on finding a used set, but can use headliner bows from other models if you know what lengths you need.
