Help decode, VIN and fender tag??
sabre67
B.C. Canada
Im trying to decode numbers and not even sure if these tags belong together yikes both tags on 67 Belvedere convertible.Thanks
Well, the VIN says it’s a ‘67 Satellite convertible. But the fender tag says it’s a Roadrunner convertible with a 273 2 bbl.
Ya that's what was screwing me around. The color and engine are correct I think the vin tag is good, but fender tag not so much
Here is what I got:
67 Belvedere Convert
Did you have the Tilt Steering Wheel too?
Good Info here ^^^^.
Satellite is a Belvedere, that's what I was thinking.
Build Sheet/Broadcast Sheet should be on the lower section of the back seat held in place by the seat springs. Hopefully you are lucky enough that it is still there and can still read it.
Well......
That is only one possible place to check.
Some cars have had as many as five broadcast sheets found in them in different locations.
