Help identify and where they go thanks
67Bar318
Fellsmere, Fl
I believe splash shield and fender reinforcement need help on identify and where the go
Some of those pieces were welded in from the factory and were removed for the mini tub. They have to do with the fold down partition. Not real sure but most are not needed structurally other than maybe the reinforcement for the deck lid hinges. The plastic IS for the front splash area.
I'm not sure about the bottom picture. I assume the springs are relocated too. Bottom picture may have something to do with that.
Top picture, second down is for the hinge reinforcement. You need to weld that back in. the curved part sits on the wheel house.
Thank you Bodyperson. Springs were relocated. Where in front do plastic shield go , are they riveted in. Thanks again for great knowledge, I 've been looking all over for some info.
The front splash shields are bolted in. They go more toward the front. They almost hide the strut rods.
