moparmat2000
Ok,
I got all the water leaks fixed on the 1999 chevy shitburban, now im having a fuel problem. Truck will start when i dribble a little gas in the throttle body, and run for a moment then it dies. I put a brand new GM ac delco fuel pump in the tank a few months ago when it went bad. The pump makes a whirring noise in the tank so i know its working.i swapped a new fuel filter into it last night and it started up. This morning its back to cranking but not starting. A little gas in the air horn will bring it to life again. Just like yesterday.
Does this truck have a return line. Im thinking mebbe its s bad pressure regulator.im thinkingof pinching off the return line to see if its the regulator. This truck uses a multiport spider setup under the intake manifold. Where would the fuel press regulator be located?
Any other ideas?
Thanks in advance
Matt
Any other ideas?
Thanks in advance
Matt
