Help with A body front disc conversion....
LRSD
Deployed
Austin, TX
I want to convert my 69 Dart front end to disk brakes. I have a line on the following parts from a 1972 B-body Charger:
Rotors
Spindles
Calipers
Master Cylinder
Besides hoses and hardware, is this all I need? Is there a link that has all the parts needed for this B-body to A-body conversion? I do not see a TECH page here on the forums. Thanks.
You will also need a set of A-body upper control arms. The early ones use a smaller upper ball joint.
I also have the same '72 B-body disk brakes on the front of my '71 Dart.
I pulled the brakes off of a 1972 Charger.
