Holley 4144 carb book
62 dodge
Minden N.V
Anyone know of or have a good manual on the Holley 4144-1 carb. I'm looking for one.
Thanks
I would also recommend this. Larry Shephard is a Mopar guru... :
Amazon product ASIN 1557885281
I have the holley 4144 for the center and on the metering plate you have booster holes. I have a gasket with all 4 holes open and then the new one only has two open. That's what I would like to find out, what one is the right one. and what do they do.
If they are necessary, can you punch the holes in the new gasket yourself???
That's what I'm trying to find out if you need the holes or not.
What do they go to???
Try spraying carb cleaner in the holes that they go to and see what they do??? (wear safety glasses in case of back spray....)
Can you post some pictures of the two gaskets and then the metering plate (and any other parts) so we can see what your are talking about specifically???
Not right now. It's still together and not ready to take apart. I will when I do though. I'm trying to get some one with holley to tell me something.
RustyRatRod is good with carbs and may be able to help if you can get him in here....
I was told by Holley that the 4144 only has 2 holes. So now I'm wondering if summit sold me a returned one that someone messed with and put the wrong gasket on it.
