Holley Stealth Sniper EFI Question
mopowers
West Sacramento, CA
For those who have installed a Holley stealth sniper efi, what air cleaner base did you use? I realize they're modeled to look like a 4150 Holley carb, but when I talked to Holley tech, they said the stealth efi unit is a bit longer than a regular 4150 carb and may interfere with an air cleaner base made for a 4150 carb.
Also, what fuel feed line are you using? Holley tech said the inlets are wider than a 4150 carb?
Why have a 4150 look-a-like efi unit that takes a different feed line and air cleaner...
i used that extension piece in the rear and made the lines leading to the unit. I am not sure about the length.
IIRC.....
Summit Racing SUM-240620B Summit Racing™ Braided Nylon Hose | Summit Racing
Earl's Performance AT915364LERL Earl's Performance Couplers | Summit Racing
There were a couple -6 fittings i used to get into the body and of course the front hose fitting but the 3" coupler was the key to kicking it off the unit into the 'T"
clear as mud?
I actually called summit to get that second part number so feel the love man.
On a separate note.....summit no longer just gives out part numbers....they email or text it to you....weird.
