May 27, 2009 #1 R rebeldart Well-Known Member Joined Jun 7, 2005 Messages 608 Reaction score 5 Location North FL Swinger, AAR hood, 340, Air Gap, Avenger carb and the black Mopar air cleaner. I need more clearance to close hood - options ?
May 27, 2009 #2 briankaplan greenduster Joined May 30, 2005 Messages 3,348 Reaction score 119 Location northern wi.- rhinelander A drop base on the air cleaner might help. Just get the saw out and cut a hole. I did it on the Duster to clear the hood. I set the top of the air filter right at the hood line. Pulls in alot of air with the dual scoop.
May 27, 2009 #3 Burntorange70 Well-Known Member Joined Feb 18, 2008 Messages 12,870 Reaction score 152 Location Aguanga, CA. A drop base will help a lot and a shorter filter can be used if needed.
May 27, 2009 #4 flyfish C8H18+N2O = :-D Joined Apr 16, 2007 Messages 2,501 Reaction score 1,234 Location Indy This is what I just put on mine...Works great! http://store.summitracing.com/partd...4294756384+4294904151+400178+115&autoview=sku
