project360
hopefully all goes well with the machine shop for the block, im excited to start building, as its
.060 over
crank turn .010/.010
shot peen stock rods
shooting for 11 to 1 compression on KB 191's w/ floating pins
voodoo, hydro flat tap, Duration 284/292, Lift .533/.552
pro port J heads, 2.02 / 1.60 with comp vavle job and oring'd
holley 750 dp ready for E-85
M-1 intake
electric water pump
all ARP hardware
accepting any and all criticism, good or bad as what ever it makes is what it makes. the goal is to just go fast! This will be a friday/ saturday night driver as i live 5 min. from the 1/4 mile
strip/ streetish, 12 month project.....:clock:
69 Dart, with sure grip, I have not looked into trans or rear gears yet, but will run an auto with manual auto vavle body 3000 stall, the car will be mini tub with street slicks, as tall as i can fit in the tub and still get the car to sit right.
---similar to---
Uploaded with ImageShack.ushttp://www.musclecarspecs.com/images/mopar/1968GSSHEMIDart/images/hemidartgss02.jpg
.060 over
M-1 intake
electric water pump
all ARP hardware
---similar to---
