Hotchkis leaf springs
69fastbackfish
Cincinnati Oh
I’m going to install new leaf springs today, I’ve heard of using stock brackets, anyone know about this? Does anyone have any tips?
One of the thing I remember is some of my suspension parts were seized on pretty good. A good spray with a penetrating oil with a couple applications would probably be advised and I found a half inch drive electric impact to be my friend.
Very true however I already have the old ones off, thanks
It's likely you'll need to replace the front & shackle bushings, unless the springs come with them. Also make sure that the OEM eye bolt diameter matches up with the front bushings. Checking the pinion angle before & after couldn't hurt either.
I used the stock hangers and shackles. Very happy with ride height. Using their provided shackles would have caused tire clearance issues and I would have been beating the headers against the ground after lowering the front to match. It still seemed slightly lower than stock.
