How a New 426 Hemi/ 440 Wedge Block is Machined @ Energy Manufacturing
PROSTOCKTOM
West Central Indiana
10-12 hours of machining to take a raw casting to retail. I am going to guess that those machines are in the $250 an hour range, so that's $2500 to $3000 worth of machine work.
This will help explain why a new block cost so much.
Tom
Wow! That is amazing. Thank you for sharing. Always wondered how you get a finished product like that. Now imagine it is 1970 and there was no computer controlled machines. All by hand or mechanical vs automated.
Originally manufactured on a assembly line machine with multiple stations, gang mill, multi drill head and multi tap head. Block goes in one end raw casting and comes out other end fully machined.
The OEM has had machines for over a 100-years built specifically for machining blocks at a fast rate. When you make a million of them a year you can afford to have custom built machines that get it on. Henry Ford had an Ingersoll milling machine in 1912 that could machine multiple blocks at a time. I saw it several years ago in the Henry Ford Museum.
The Henry Ford’s Ingersoll Milling Machine and Mass Production at Highland Park -- The Henry Ford Blog - Blog - The Henry Ford
Tom
