How can I tell what is a Dana 60
bbdemon
Member
I know they have 60 stamped on the bottom right side but I have come across a couple 1 Ton vans that don't have any casting numbers or the 60 stamp anywhere. The bolt pattern on the cover side matches the same as the spotters guide I have from this forum exactly. Is their any other way I can tell besides the 60 stamp?
Dana 60's have full floating axles in trucks.... Large hubs that stick out with six or 8 bolts holding them in..... There should be a cast in 60 70 or 80 on the driver or passenger side of the carrier... 60's and 70's are real similar in size and 80's are huge.... Most likely it will have a stamped in Dana on the diff cover unless it's rusted beyond recognition
Usually says Dana 60 as shown in the pics
All Dana 60 housings are marked with a "Bill of Materials" number and a date code (Figure 2). BoM numbers are found on the back of the right axle tube, 2-3 inches outboard of the center section. All Dana 60 differentials are also marked with a date code. The 'font' for these stampings is a sans serif style and the characters are about 1/8" high. Particularly for the axle tubes, the stampings are faint, so it is important to clean the area well and to visualize them in good light. The BoM number is a 6-digit number with a one or two digit suffix separated by a dash: XXXXXX- X. Date codes are found on both housing and differential and are formatted MM DD Y. Date codes are found inboard of the BoM number on the housing, and on the side of the cylindrical part of the differential. The year code on housings is always one digit and on differentials can be two digits. Housing date codes are followed by a letter (A, B, or C) which may indicate the work shift or factory line. Some differential stampings also show this letter suffix. Zeros are not used in month and day codes. Wide variation in spacing of the components of the date code is seen, and it is not unheard of to see two date codes stamped into a housing, one above the other. These two date codes are usually within a few weeks of one another.
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-72 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
4.56 Powr-Lok 603109-6, -7, -8
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
74 E body 5.38 Powr-Lok 603425-1
77-78 Retail 4.10 Trac-Lok 603831-1
Maint.
67-70 D200/W200 Std 602423
68.5-70 D200/W200 Std, Powr-Lok 602010
69.5-72 D200/W200 Std, Powr-Lok, Trac-Lok 603016
71.5-75 D200/W200 Std, Trac-Lok 603236
76 D200/W200 Std, Trac-Lok 603769
77 D200/W200 Std, Trac-Lok 603775
78 D200/W200 Std, Trac-Lok 603892
71-75 D200/W200HD Std, Trac-Lok 603237
76-78 D200/W200HD Std, Trac-Lok 603647
70-71 B300/M300 Std, Powr-Lok, Trac-Lok 603160
71.5-74 B300/M300 Std, Trac-Lok 603313
74.5-75 B300/M300 Std, Trac-Lok 603516
76 B300/M300 Std, Trac-Lok 603645
76.5 B300/M300 Std, Trac-Lok 603768
77-78 B300/M300 Std, Trac-Lok 603774
78 B300 Maxi Std 603832
Axle shaft dimensions vary in Dana 60 axles. Dimensions of semi- floating (passenger car type) axles shafts are shown below. Shaft lengths are measured from the outer flange face to the inboard end of the shaft. Note that the right axle shaft is always shorter than the left, so unlike the Chrysler 8 3/4" axle, Dana 60 axle shafts will not interchange side-to-side.
BoM Dia.-splines L shaft R shaft
602957 1-1/2"-23 29-21/32" 28-9/32"
603109 1-1/2"-35 29-21/32" 28-9/32"
603222 1-1/2"-35 31-5/64" 29-11/16"
603347 1-1/2"-35 28-7/16" 27-1/16"
603080 1-1/2"-35 30-7/16" 29-1/16"
603226 1-1/2"-35 30-7/16" 29-1/16"
603425 1-1/2"-35 24-7/16" 23-1/16"
603831 1-5/16"-30 32-5/8" 32-5/8"
Dana 60 Gear sets
Standard Series
P4529919 4.10:1
P4529920 4.56:1
P4529921 4.88:1
P4529922 5.13:1
P4529923 4.38:1
P4529924 5.57:1
P4529925 5.86:1
P4529926 6.17:1
Pro Series 9310 High Strength Material
P4529927 4.10:1
P4529928 5.13:1
P4529929 5.38:1
P4529930 5.57:1
P4529931 5.86:1
P4529932 6.17:1
P4529933 6.50:1
Part Numbers
382S Differential bearing cup
387A Differential bearing cone
HM88510 Drive pinion outer bearing cup
HM88542 Drive pinion outer bearing cone
HM803110 Drive pinion inner bearing cup
HM803146 Drive pinion inner bearing cone
18888 Drive pinion seal
18891 Drive pinion seal (Differs in configuration of lip)
P4529485 Powr-Lok Diff. Clutch kit (Flat Plates with composite)
2852523 Powr-Lok Diff. Clutch kit (plain steel Flat Plates)
P3571032 Differential Bearing Adjustment Shim Package
P3571030 Drive Pinion Front Bearing Shim Package
P3571031 Drive Pinion Rear Bearing Shim Package
P5249453 Shim Kit (Includes 030, 031, and 032 Packages)
P4529488 Ring Gear Bolt Package
RDS6095 Cover gasket (Felpro)
A7 Axle bearing
A7LK Axle seal and retainer kit, left side
A7RK Axle seal and retainer kit, right side (discontinued as of March, 2001)
