How do I know?
74Dart318
az
So how will I know what type of rear end my car has? Measure it for the size or will the numbers on it tell me what i need to know?
thanks
Here use this.
You sure are on the ball Burntorange70.
All right so I have an 8 1/4 inch rear
I was going to check the fluid level since I never have
I am not sure if it ever has been
Is there an adapter i can buy that will fit the plug so I can check the fluid?
(dumb question probably lol)
Thanks
Thanks
Just stick your finger in the hole. Fluid level should not be more than a 1/4 in from the bottum of the bolt hole.
Ya i know that part but do I just use a regular ratchet to get the plug out??
I thought a half inch drive ratchet with a short extension would get that plug out?
