How Do I Remove Fuel Tank 1964 Dart GT
flyinbysocal
Member
San Diego, CA
Does anyone have any advice for me on how to remove my fuel tank on my 1964 Dart GT? Any help would be appreciated, I think it needs a cleaning... Thanks
Clean the threads on the "J' bolt part of the fuel strap, on the passenger side. Clean the area around the filer tube --the best you can. I found out by luck the tank drops much quicker if you do not empty all the fuel.(something about weight & gravity).
It should have a ground strap next to the fuel sender inlet. try to remove with out breaking (good luck).
now have a jack & a piece of plywood under your tank snug it up-- but do not cover your fuel strap.
remove sending unit wire, (cut the rubber hose from frame to sender) loosen filler neck at the 1/4 panel, remove nut on "J" hook-- lower tank--- done---
Lawrence
