How do you remove a stock gas tank from a 1964 valiant
alcronk
Valiant64
Coquitlam B.C. Canada
Can someone please send a newbie the steps needed to remove the stock gas tank from a 1964 valiant or if you know of a web site that would be great THANKS valiant 64
Put the rear on jack stands. Remove the three screws from the filler neck to the quarter panel. Remove the screws from the filler neck grommet in the trunk. Remove the sending unit wire and the fuel supply hose from the sending unit. Get a floor jack under the tank. Then remove the nut holding the tank strap on. It works best with two people as you need to gently drop the tank while the person on top guides the filler neck out of the tank. Installation is the exact reverse.
When it goes back in ..put a little bit of Vaseline on the filler neck grommet.
Thanks for the information we just had a few inches of snow So it will have to wait for a few days till we get some better weather Thanks valiant64
