71Scamper
Mopar runs thru my veins!
i'm replacing both doors on my scamp. They fit quite well but still need a bit of adjustment. the gap is too big between the door and quarter panel. need to slide the door back an 1/8 inch. the problem with that is that the rear sail window and the drivers window will slightly overlap. also, the front quarter window will have a slight gap between the A pillar and the window. how is this adjusted, if even possible. I do see all sorts of slotted bolt holes and rods with slots in them.
Is there a free resource on here like a factory service/build manual?
