How to interchange your flywheel(neutral unit ,internal balance )to a external balance unit
Mrmopartech
St.Lazare Quebec Canada
The pics I am posting is for a person that has a neutral/internally balanced flywheel and wants to install it on a externally balanced and needs to drill holes to counter balance the rotating assembly,mrmopartech
You also need to look and read the diagrams,as there are distances and degrees and minutes to understand the positions to drill holes and have the unit balanced for your engine,mrmopartech P.S.please email or PM for further info and how to read the diagrams or call me,scott
These are different than the readily available info how, exactly?
If you ever looked or have seen a Mopar race manual,these pics are right out of the book,and I have used these for decades,with no issues,only issue is the person that does not understand or know how to read the pics,thanks why I ask if you have a issue,I would explain it too you when you call me.Now if you think Mopar is wrong,please state your point,Mrmopartech
