All parts are located in Walton NY 13856. I gathered up most of my mechanical stuff and took pics. I want to do it as all or nothing. Price for entire lot is $2500. Looking to pare down my inventory so I can actually work on my car. If it doesn't sell this way after a while I may sell individually but would really like to sell all in one lot. There's a lot of good stuff and also some filler stuff. A lot of the 69 Formula S Cuda stuff is in here. The torsion bars, the 340 HP exhaust manifolds (the butterfly even opens freely), the 340 intake and the 4 speed trans with the bell, inspection cover, shifter with handle and ball (shifter handle must have been broken as it is welded, you'll never see it with the boot on but it is not perfect), the clutch rod and the shifter rods are all there. So there is almost a complete 4 speed set up. There is a set of pedals from a later year A body as there is a switch on it. There are a bunch of fans and some pulleys. The first bare block in the pics is a 72 360 block that is race prepped, priority oiling on the mains, clearanced for roller lifters, bored .060 with the water jackets filled so it's not gonna be a good street block. Great for a racer though. The next block is an 87 360, the heads crank and 4 bbl intake are with it. The last engine is another 360 short block that is freshened with a new hone, zero decked, new rings, it has 9.5:1 JE forged pistons, new bearings and the crank has been internally balanced with mallory metal. There are timing covers for all plus a 273 timing cover. The 8 3/4 rear housing and axles are B Body. There a new studs in the axles. A power steering set up with the box and pump and bracket. There is some slant 6 stuff in the bottom right corner. A balancer, pulleys, oil pan, valve cover and rocker assembly and a 3 speed manual trans bell. It represents most of what I have I'm not keeping for my car but I may find a few more trinkets as I go through my garage. If you have any questions or need better pics of anything let me know. Thanks, Woody.
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot001_zps9a7b0414.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot002_zps2a211d18.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot006_zps3c9c1a4a.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot007_zps70460db3.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot008_zps5d52d7fe.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot009_zps5f3b8573.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot004_zps5944a19b.jpg
http://i1296.photobucket.com/albums/ag1/woody3037/mechanicalpartslot003_zpscb98d2fb.jpg
