[FOR SALE] Hughes Custom Cam for 360 with 273 Manifolds
Valiantjim
Bayfield, CO
I've disguised 340/360 engines as 273 Commando (Charger) 's a number of times over the years. I never went to the point of being truly stock appearing and was going for that with my 1966 V100. I worked with Hughes to come up with this very custom hydraulic roller grind for a late 360 LA (1990) using the factory 273 intake and exhaust manifolds. Port matching the manifolds is part of it but the restricted flow is a given. The front cover and water pump configuration were planned as 273 as well. It won't perform to the level of a hot 360 but it well definitely be shocking for a 273. Store that factory original engine on a stand and have some fun!
SER1234ALN-112+4
212 intake duration @.050 .300 lobe lift .450 valve lift
224 exhaust duration @.050 .300 lobe lift .450 valve lift
112 lobe separation angle
4 deg advance ground in
Five years ago it cost me $450 and a two month wait. You won't get a custom Hughes cam near that these days. I'm asking $400 plus shipping from 81122
Update: I couldn't find the cam card and used specs as discussed in an email with Hughes. I just found the card, confirmed part# on cam, and found the final specs are slightly different. The assigned part # is actually SER1224ALN-12. See card atchd for the rest.
As this is a custom grind with specialized use I understand interest will be limited. If you can use it please make an offer. I won't give it away but I don't expect to get all my money back. Thanks!
