Ididit shifter linkage
72SwingerJosh
Pennsylvania
Has anyone used the ididit shifter linkage for a 904 to 727 swap. I was looking for a stock set up but can't find one and was looking at these. Thanks
Maybe only chevy and ford use em. :D
Betcha Tony (whitepunkonnitro) has em.
He's a good guy and you can trust him.
I bit the bullet and got one and used it. Worked great no problems. Just follow directions. Also went with a lokar throttle and down shift kit. It is a lot better than the stock set up. Hope someone see this if they are considering spending tons on old stock junk.
Josh, I just found this post and had some quick questions about the kit. I've got a semi-finished 73 Duster that was converted from /6 to a 318 with 904. It's currently having issues shifting into park and into lower gears from the column. Seller said he tried adjusting it, but couldn't get it quite right. I can see tons of slop in the current linkage. Was thinking of picking up this kit to just eliminate all issues.
Does this come with instructions for both 727 and 904 trans setups? Prob also going to grab the same Lokar linkages as well. Thanks for the info.
