ignition breaking down
TimDart
UK
Once warmed up my car starts to break down under acceleration, it feels like something is cutting out. The ignition is all new FBO high output stuff. I cahnged the coil which worked well for about 10 mins before the problem reemerged. Since then ive changed the distributor and the ECU without any positive results. I even looked under the hood in the dark to see for electrical tracking, nuthin.
Any suggestions? Its getting me down.
I had a similar problem that was caused by a bad dist. It had weights sticking and bouncing aroud in it and the pick up had a bad connection in it. Change of dist. and prolem went away. That was just me though.
Yep, i changed the dizzy, i have a less than secure connection at the Ballast resstor, so i'll heck that next.
Did you replace the plug wires when you installed the FBO system? I know Don said that lesser wires will arc out badly.
