Well I had about 12 spark plugs including the ones in the car, so what I did was with a marker draw a line on the plug marking where the open side of the electrode was[or 180 to the strap] then with all plugs out of the motor, [so to have many available] started screwing them in till I could get'em one at a time to end up where I wanted them to point
[off center to the exhaust valve] that way eventually you will get a plug that lines right up given it's in the right hole with out washers.
So outta 12 plugs I got them all indexed with no washers.
All of the plugs and threaded holes were/are clocked different when tapped/dyed.
