Information on 1964 valiant well liner install wanted.
Mrroth71
Member
Sweden
I´m about to TRY install a well liner i bought from Hydro-e-lectric, but i´m not sure how .
Does anyone have a picture of their 64 Valiant convertible well install?
Best regards!!
Stefan from Sweden
This is a C-body well install, but yours will be similar. Use spray adhesive on the wheel houses and cross brace behind the seat, and strip caulking on the outside where the well meets the body. Most of the well will just "float". I believe your top is fastened to the outside of the body rather than inside. The metal retainers hold the top AND the well in place on the outside of the body. Once all that is installed, then the stainless trim with the rivets for the boot go on. I hope this helps. If you need more pics, let me know and I'll post what I have. http://www.forabodiesonly.com/mopar/showthread.php?t=219861
Thank´s for the info!
When i bought my Valiant there where no well liner installed, should it be any special bracket ,or??
// Mrrroth
