zac_F71
Well finished up for the night - installing ARP main studs/12pt nuts in my 67 383 block and ran into a problem. Pictured is the No.5 main cap, and rear main seal holder (both stock pieces)the stud on the far side in the pic is a good 1/4" taller
Tried swapping a stud from No.3 main same side and got the same result, evidenced by the last pic with the oil pan resting on the stud/motor
12/67 383 - I am the first to touch the rotating assembly since it was new in 67
Milodon 8qt oil pan
ARP studs w/ 12pt nuts
Stock main caps/ rear seal holder (for now - going with 440source billet holder)
Milodon 8qt oil pan
