Installing RMS 3 inch inboard boxes
QuintinMotorCompany
Georgia Vermont
My car is coming back from the body shop and we need to do my spring relocation kit... a couple questions... How do we know if everything is at the right angle it should be and everything is squared away. ?
Any tips or suggestions before we start digging in? Thanks a lot.. :burnout:
what you will be doing is leaving the outside portion of the frame and cutting out the inside and back out. leave the stock bracket on to measure off of. you can drill a hole using it as a guide to help keep everything lined up also.
Measure but you'll see everything is pretty straight forward as to were they need to go.
I did this to my 68 Barracuda. I cut both sides of the frame. If I was going to do this again I would leave the out side frame. I with I had a better pictures
