Intake gaskets
rtee007
Deplorable Texan
Baytown, Texas
So....I can't seem to find the cork gaskets that go on the front and rear of the SB intake. Do they exist w/o having to buy the complete set? I bought the Edelbrock gaskets with my Air Gap and don't see them.
black rtv,or you can have mine
Most of us use RTV ot "The right stuff" sealant for the ends.
For either stay towards the inside of the rails where the cork used to go and put about a 3/8 bead all along it and into the corners where the heads and block meet.
Set the intake on as fast as you can and get bolts in it and allow the sealant to set up for at least a few hours.
It helps to have two people to set it on so you don't end up sliding it around at all when it goes down.
Make sure the original locating dowels are removed from the block first.
Thanks, I will use RTV as indicated.
