Intake manifold
wireweld
South Dakota
Where can I get a intake manifold like the edelbrock pro flo xt made for a small block?
Edelbrock EFI Chrysler Intake Manifolds
PRO-FLO XT MANIFOLDS
For 440 Wedge Chrysler (1500-7000 rpm)
The Pro-Flo XT intakes are engineered with a large plenum and long tapered runners to deliver maximum horsepower and a broad torque throughout the rpm range (1500-6500 rpm). A new front mount 90mm throttle body (available separately) feeds the intake all the air it needs for maximum performance. Pro-Flo XT intake manifolds are available in choice of Satin aluminum or black powder coated finish with contrast machine.
Application Part #
Pro-Flo XT B/B Chrysler 440 Wedge (Natural Aluminum Finish) 7144*
Pro-Flo XT B/B Chrysler 440 Wedge (Black Powder-Coated Finish) 71443*
Fuel Rail Kit for B/B Chrysler 3/8 NPT Inlet 3644
Throttle Body Recommendations: Edelbrock #3818, #38183, #3869 or #38693. Installation Notes: Recommended gasket: Edelbrock #7255. Manifold Dimensions: A-9.7", B-9.6", C-19.9". Port exit dimensions 1.12" x 2.12".
CHRYSLER 413-440 V8
VICTOR 440 EFI (Up to 7500 rpm)
Victor 440 EFI is based on the Victor 440 manifold #2954. For high performance street and competition or high-rpm 413-426-440 c.i.d. Chrysler V8s, it has an all-new runner design that delivers maximum power from 3500 to 7500 rpm. This single-plane intake manifold includes nitrous bosses and is designed for standard flange throttle bodies. Match with Edelbrock Performer RPM or new Victor Chrysler 440 aluminum cylinder heads for maximum performance. Will not fit 1962-64 Max Wedge heads.
Application Part #
Victor 440 EFI 29545*
Fuel Rail Kit for use with #29545 and Bosch style injectors 3/8 NPT Inlet 3640
Fuel Rail Stands for use with Pico injectors (Qty. 4) 3619
Throttle Body Recommendations: Edelbrock Edelbrock #38783 or #39783.
Installation Notes: Recommended intake gasket: Edelbrock #7225. Manifold Reference Dimensions: R-1.16", F-1.01", W-1.15", H-2.17", CH-6.25", CA-0°. See manifold reference dimensions. Port exit dimensions: 1.15" x 2.17".
CHRYSLER 340-360 V8
SUPER VICTOR EFI (3500-8000 rpm)
Super Victor Chrysler EFI is based on the Super Victor Chrysler manifold #2815. For high-rpm 340-360 c.i.d. Chrysler V8s with standard port location heads, it delivers maximum power from 5000 to 8000 rpm with peak torque at 5500-6000 rpm and peak power at 7000 rpm. Precisely positioned and machined injector bosses deliver excellent fuel spray patterns and maximum power. Universal 4-Barrel Throttle Bodies, fuel injectors, fuel pumps and regulators are also available to complete your EFI system.
Application Part #
Super Victor EFI 340/360 28155*
Fuel Rail Kit for use with #28155 and Bosch style injectors 3/8 NPT Inlet 3641
Throttle Body Recommendations: Edelbrock #38783 or #39783.
Installation Notes: Recommended intake gasket: Edelbrock #7276. See manifold reference dimensions. Manifold Reference Dimensions: R-1.21", F-0.94", W-0.98", H-2.15", CH-6.30", CA-0°. Port exit dimensions: .98" x 2.15".
