Interior trim color help...
68-GTS
Super " Senior " Member
On The Loo...
Is it possible to find the proper interior trim colors from a build sheet ?
What i mean is the proper dash / console and interior door paint Colors.
Or does anyone know of an online interior paint code chart?
I'd like to match the original interior colors as close as possible.
on your fender tag the exterior and interior colors are listed.
Example 1967 barracuda with a code of DD1 EE1 DD1
Dark blue interior with dark blue painted top/bottoms of the doors.
Light blue exterior.
Look at the tag and check it against a fender tag decoder...
But will it just say Dark blue or the actual color name and or color code.
Also where do i find the fender tag decoder or is that the same as the Vin decoder on the home page ?
No.
It will lead you to the color via a chip chart.
Go to this website and you will find all of that info and more.
http://www.mymopar.com/index.php?pid=31
First decode your fender tag...this is fun to do cause it tells you a lot about your car.
Second go to the paint chip section and look up your year and model.
Have fun with it.
Mop
No.
Have fun with it.
Mop
Thanks but i actually found a SEM Shadow Blue thats the perfect console color match.
I brought the console in he sprayed a sample and wow it was bang on.
