Is an 8.25 rear with 2.74 gears upgradable to better gears?
392Mopar
Hazlet NJ
Hello,
I was wondering if an 8 1/4 rear end with 2.74 gears is upgradable to say 3.55-3.91's? I heard that some of the rears with lower(numbered) gears are different than the higher (numbered) gears,the housing and carrier was different, but I dont know what the cutoff is. Thanks. Looking into rears for my 72 Duster and want to get something that I can put better gears in.
Butch
You will like the 3.55 gears if you are looking to get that big take off low end power, Good gear for an upgrade and i am sure it will change right out.
2.45 gears used a different carrier. Above that will swap. So, yeah, the 2.74s will take a 3.55 or 3.91 gear.
grumpus hit the nail on the head, I would recommend checking out randy's ring and pinion ringandpinion.com they have alot of options and if you have quesitions you can call them up - I've had great experiences with them
