Is ecu needed on Msd pro billet plug and play
Daniel J Thurston
N.Y
Hi I have a 70 duster 318 I am trying to figure which harness I want to use and what parts I still need. I can't find my Mopar ECU box thing... I have 2 wiring harnesses as well one with a ECU box plung and one without.
The distributor is a msd pro billet plug and play. Street fire wires With a acell super coil. I am not sure if this system needs the ECU box or not.
Also if not than do I need the ballast resistors as well or not
I'm not really a electrician so I'm out of my element here also when I had the msd installed on my 74:they had some type of aftermarket box like a relay or something between the batteries and the coil I'm wondering if they used that instead of balsat. Idk any help would be great ...
And if anyone has a diagram for me to follow you would be my hero. Thanks
There are a lot of MSD distributors out there. If it has only one plug with two wires, purple and green, it needs an external module. If it's something else, post a picture or part number for what distributor you have.
