CUDAGUY
aka Prince Valiant
anyone thought about using two k-car turbos?
The way I think of it.
2.2 + 2.2 is 4.4L really close to the 4.5L that a 273 displaces. A nopo 273 has 8.8:1 compression, with some thick headgaskets should be around 8.4-8.5:1......perfect for a turbo app. These turbos are capable of 17-18 lbs and have a 2.5 outlet that accepts the typical 80's-90's chrysler ball flange.
So heres the plan.
Ive got a 2-barrel 273
I will whip up basic log style manifolds
use two 2.2L K-car turbos
2.5" dual into 3" single with cutouts
some kind of small intercooler
#302 heads, stock, unported, cleaned up a little
stock 340 valvesprings
stock 340/360 cam with hyd. valvetrain
thicker headgaskets
performer intake
stock replacement electronic ignition
1405 edelbrock carb
no more than 10 pounds of boost
concerns
using an edelbrock carb in a blow through application
strength of stock 273 cast pistons
what range spark plugs to use
any thoughts or suggestions?
Thanks,
Jared
So heres the plan.
thicker headgaskets
performer intake
1405 edelbrock carb
concerns
Thanks,
Jared
