kb 190s intalled?
project360
Tucson
looking for info on someone who has installed kb 190s on a stock and squared deck height. my question on a 360, is it still in the hole or does it poke out a bit. this is a .050 dome which isnt much.
been running them for awhile in my 360 ,they are above the deck never measure but it looks like just the dome part is up
run the with the 509 cam car run in the 12.5ish
Agree with 01heavy, just installed mine a bit ago. Haven't measured either but I would guess they aren't more than 0.030 to .040 out of the hole.
cool.... what heads are you guys using... have you milled the heads to achieve more compression and tighter quench, ive seen some just installed with J heads and the mopar thin gasket and be done, no real math involved, not sure how they run that way though.
