kelsey hayes brake pics
snowmobiler7c
Newport Mi
Just curious if anyone here has a pic of the correct way the brake lines are routed on the 67-72 kelsey hayes setup.
I have my calipers/spindles/rotors installed now. What i am looking for is how the rubber hose bracket is mounted to the caliper. And also there must be a hard line that runs from the caliper to the rubber hose correct??
It probley does not help i only have one bracket so not sure what side of the car it will go on.
thanks
mark
There's someone on here that's starting to make those if you need one...just can't recall who...
