snowmobiler7c
I will post a link below the auction ends soon. UP for auction is a pair of 1966-1972 Mopar A body kelsey hayes disc brake calipers. This is the 4 piston caliper used on small bolt pattern cars. These calipers are being listed as core or parts calipers. Both look to be in good shape but will need a rebuild, someone has put a helicoil in both the hold down bolt holes for the brake pads on one of the calipers. Both calipers still have the top crossover lines and bleeder bolts installed. I was able to get all four pistons on one caliper to compress and only three to compress on the other. So only one piston is seized of the 8 pistons. This item is being sold AS IS and has been described to the best of my ability. Check my feeback. Thanks
Located in Newport Michigan, starting bid is $50.00 plus shipping.
http://www.ebay.com/itm/261061036130?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
