kickdown rod to carburator 318 4bb
spiner1963
spiner1963 1970 dart
kingsville Ont
Rating - 0%
0   0   0
wanted to fit 1970 dart 318 4bb kick down rod from carburator that arme only also do you know about nutral park reverce switch location,, building car from scratch had collum shift converted to floor councel shift have not figured out wireing nutral switch please help:newb:
Does your trans have the three prong switch in it right behind the shift linkage?
Like this?
most common one ive found single brown wire from starter relay switch to single pole switch un driver side tranny
Well anyway, If I remember right the two outer prongs are for neutral safety and the center one is backup lights.
