Lakewood bellhousing help needed
50coupe
Member
KINGMAN, AZ
For the hemi destined for my Cuda, I have an older Lakewood with a four digit part number (#1531) where the newer versions have a five digit number. It also has only one starter mounting point where later ones have two locations. The TTI headers I have require the common mini starter I believe. I have not been able to find out which flywheel (tooth count) Lakewood made this bell for. My question is: Which or is there a flywheel that will be compatible with this bell and the starter required?
Thanks in advance
Victor in Kingman/Mesa AZ
You only have 2 choices. 130 or 143 tooth. Your starter holes may or may not need modification, I don’t know, just mock it all up and see?
Only trouble is I don't have any flywheels to try a mockup. Aren't there 3 possible flywheels that might be used? 130,143,and 172(direct drive starter only?)? Thanks
If the early Lakewood is only setup for the 172 then I need a different bell. I just can't find the info.
Besides, Lakewood scatter shields are notorious for not aligning the transmissions well. Do you even have the block saver that goes with it?
Do yourself a favor and get a new one from Quicktime.
