LBP axles/Brakes
AdamR
Big Member
Bethel, CT
I want to start collecting parts to go BBP on my car. Im going to get Moser axles. What rear brakes to I need to run with them ? Will I need to change wheel backspacing ?
When you call Moser, you tell them big bolt pattern and big brakes(as opposed to small pattern brakes). You can use almost any brakes then. Just get from the housing out: backing plates, shoes, springs, adjusters, drums, etc. Any big pattern car set-up should work. I went with 11 inch set-up. I didn't like the shape of the backing plates I had, I ordered new ones from the dealer. I think I said 80 something Diplomat. The big pattern with big brakes axles will make flange to flange slightly wider. 1/2 inch or so?
I got the Moser axles and B body brakes for my 69 Fish.
Be aware that this setup will move the wheels out an inch
or two. I needed more wheel backspace with the Moser setup
than I did stock.
-Shupe
ps first post! Nice site and forum.
