Howdy all, cosgig here. I have up for sale here some LBP disc brake items. Included in this ad are the spindles, caliper brackets, prop valve, and all necessary mounting hardware. Also included but not pictured will be the bearings, nuts, castle nuts and dust caps for the spindles. Heres the details...
I blasted and painted the caliper mounts and spindles, which are in pretty nice condition. There was a small amount of detereoration between the dust shields and the spindles, as the shields were rusted away, but it does not interfere with the mounting points in any way. One of the pad hold down clips is cracked also, but I think they can be had at the auto parts. All of the bolts are good, the prop valve sensor looks like it may need replaced but would probably work as is.
My price for what you see here is $100.00 plus $17.50 shipping in a Large USPS Flat Rate Box, anywhere in the CONUS!! I think the Flat Rate Box can go to Canada for $29.95, but I would want to check before quoting that for sure
Now, if the buyer desires, I have all of the rest of the brake items that I can include in the sale also,... there is one good rotor, both calipers are just cores, and I have the upper control arms, which are not fully cut off the frame mounts. I'll include everything else but the UCA's for just the additional shipping if the purchaser wants it, and for an extra $50.00 I'll include the UCA's. They need to be blasted and painted, and they are crusty so I cant promise that they will be perfect when done, but they are useable.
As usual, message with any questions and enjoy!! Geof
