CodyS
I found a couple of 318s in two old case combines the other day. I was wondering if they were anything worth trying to buy. Both of them had tags on them that said LH 318 488. Both block were 68 castings. I was wondering if they might of has large valve higher compression heads on them. I know the old Chevy 327 that they put in combines had large valve high compression heads . Did chrysler do the same or are they just your average 318 just different application?
