Loadflite vs torqueflite to put behind my 471
MOPARMAGA
A-body or nobody
Yakima Wa
is there any difference in those 2, there's an identical look to them except for the timing hole in the case of the truck trans
The trans is from a 77 dodge 3/4 ton 400 4bbl. It came with a "low stall" converter.
I was just wondering if there are any internals which would make it a better candidate to build over a passenger car 727 & take the power the 471 will make. Obviously not trying to run it stock, (this is for my dart)
Most large [ Dual-wheel ] RV,s had the hole in bellhousing
all of them I ever tore down had 4 gear front and rear planetary's
Good heavy duty OEM parts.
Cool, thanks for that info.
I thought "Loadflite" was the AMC version.
U right I had one with a brake behind my stroker 401 ## surely fellow knows difference in bellhousing bolt patterns !!!
AMC
shouldn't have hole in bellhousing
Also !!!
AMC is a torque command.
there is little difference in a truck trans and the 3 gear planetaries are just fine. If it was a big difference every truck to ever hit the scrap yard would have the trans gone first. Day. And that’s just not the case.
People get them confused
They are Torqueflite
With Amc specific bellhousing 1972 they swapped to 727 dropped Cast iron Brg Warner
I just looked and according to wiki (I trust as much as I can throw my house), the Loadflite is the truck transmission. Maybe more heavy duty?
Guy has 200 3/4 ton truck he wants the best oem stuff Mopar offered if RV trans doesn't have the brake tailshaft he is business !!
No doubt 3 gear is fine / but he has 3/4 truck so 4 is better if he has such !
I bet mine is a 4 gear set up also because vehicles are similiar.
Me and my buddies helped a girl in school put a 401 in her Levis Gremlin. That thing would haul the mail. lol
I love me some Gremlins
I had a 64 American that the 401 sroker was in HERMAN LEWIS ) built engine he had
Over 200 wins and 19 world Records using AMC power .
Well you know, AMC had GREAT port configurations. I think that's what Fred Brewer designed his big block Mopar heads around was those AMC style ports. They were the shizzle all through the 70s for pro stock.
That's a great way to put it thank you
Yes, I'm trying to figure if it's a better starting point to build for my 471 stroker dart
Even a glide is nice if u are racing
Just saying # I love my Heavy 727 its robust and solid but it eats some power to function
