[SOLD] Long round big block intake
badlilred79
badred360
Crossville TN
Rating - 97%
64   2   0
I have a factory set of long ram 413 intake 61 to 63 I believe $600 plus shipping as is what you see is it in Crossville Tennessee
View attachment 1715931721I have more photos so check it out
I'll look mon they've been in Dad's Barn for years we actually discovered them we forgot about them lol I'll get some pictures of the backside tomorrow
You should look around for any of the Hardware and linkage that goes with them. Why is it always missing?
Have the intake flanges been cut where they bolt to the heads?
That is what they look like from the factory. There is a plate that fills the gap and blocks the heat crossover passage.
If it was a solid flange how would you get then wrapped around each other?
Don't they have a cross over tube to heat those choke wells?
you will need the crossover tube, it connects the two plenums on the intake side. Has nothing to do with the chokes. Some crossover tubes have a pipe threaded fitting to connect a PCV to.
You don’t need heat to the chokes, will be a bit cold blooded but works ok in the summer. For the chokes they use elbows from the exh manifold to the bottom of the plenum for heat and a outlet pipe the goes into the head pipe about 6” down from the manifold.
there are many pieces to make one complete. Some are reproduced, but it adds up quickly
This one has the bellcrank, but the top end should have a circle. This one is cut off. Can weld it back and make a hole again easy enough.
someone has cut off the mating flange to the exhaust manifold on one , that will be hard to replace without another one to cut it from . thats how the chokes get heated . they would be a hotrod item .
These are the long version that make torque down low correct?
Is there a linkage kit available or a way to fab one?
Could these be used on a pickup truck?
Could they be run with exhaust headers?
I don't need any of the heated choke stuff living in Atlanta.
I I'm sure you can make them work there's plenty of room in the engine bay of a truck and I think it's a low-end torque for the manifolds are and I'm sure they could be running with the headers too where that one is cut on the bottom it has no effect with the carburetor it's just for the choke stuff it's got some of the linkage you can go in and fabricate the link it should be pretty easy to fabricate I think AA transmission and there's another place makes parts for them it has some of the linkage on it make an offer if you want them
