Looking for a list of nuts and bolts to put together a 318 and 904 in an early a-body
Jcon82
Active Member
Providence RI
So I'm putting togther a Dart from a roller that came with very little hardware. I havent worked on cars for a while so I no longer have buckets of spare bolts. I'm going to have to go to the hardware store buy it all. Does anyone have a list I could use for things like bellhousing, engine mounts, starter bolts, accessory brackets ect.
Sorry for the most noob level question.
What year?
Parts book should give you a blow-up diagram with all the bits and pieces. It won't give you the sizes though... just "bolt" but it'll be a good start on what is ahead.
K frame in the car?
If the engine is complete and the front suspension is present.
Start point:
Engine mount bolts
Steering gear
Starter
Flex plate bolts
Trans to motor bolts..
Trans Mount
Trans cross member
Drive shaft
