Looking for help with paint prep
Stlrfreak
Maryland
So have front end off my demon for new bushing kit . Parts that came off being sandblasted . my problem is getting area behind control arms ready for some primer and paint . darn grease is like baked on and contours make hard to scrape,and cant use power washer in garage. Any suggestions on how to get it cleaned enough to prime and paint
Use a wirebrush to get the caked stuff off, then wipe it down with lacquer thinner or something.
Anyone hear anything about siphon feed sand blaster from walmart
I have never seen a siphon fedd blaster that was worth messing with. If you are going to sand blast, a pressure pot is the only way to go. You will need lots of cfm from your compressor tho.
The oven cleaner would be worth trying, I have used it for different projects in the past and it worked well.
