Lots and Lots of parts
RTom
Depressingly A-Bodyless..
Nampa, Idaho
I am starting to part out a 73 Dart Swinger. I am planning on listing most everything on here and if it doesn't sell soon, I'll list it on some other sites. If you don't see something you are looking for, just ask me. Lots of these parts are in need of a good cleaning, the car was pretty dirty. Some parts I'm unsure of the names on so I tried to describe where they go as best as I can.
Front Bench Seat - $50 (has some tears on the driverside as you can see, but other than that it is in good condition).
Rear Seat - $50 (the top seem is coming undone as you can see, but I don't think it would be difficult to sew it back up together)
Armrests - $5 each (one front is ripped, one rear one is missing the top of the ashtray)
A Pillars - $40 (good condition, with little to no scratches that are visible when mounted)
Door Handle Cups - $10
Door Lock Knobs - $2
Turn Signal Indicator - $10[/B] (good condition, white trim paint could use touch ups)
Rear Window Plastic Trim - $40
Front Window Plastic Trim - $40 (some of the mounting screw holes are broken, but it doesn't effect its mounting nor can you tell when it is mounted)
Radio - $50 (no cut wires, all the knobs work)
Heater Switches - $20 (comes with cables, missing one knob)
Window Rubber - $30 (the rubber 'gasket' that the windows seal against when cranked all the way up)
Head Liner/Window Metal Trim - $40 (the part that goes on the inside of the door on the edge of the headliner)
Chrome Window Trim - $50[/U][/B] (where the windows crank up to)
Complete seat belt set - $50[/U][/B] (includes all the bolts, the should belts up front, some are dirty, could use cleaning or a re-dye)
Rain Gutter Chrome - $60[/U][/B] (a little warped, should straighten out when re-installed)
Kick Panels - $25[/U][/B] (2 have insulation, usual wear marks/scratches)
Glove Box Door - $25
Instrument Cluster - $60 (some of the trim paint could use touched up, missing the wiper knob, the light switch relay could probably use being replaced)
Rear Window Chrome - $50 (could use a cleaning, but good condition)
Windshield trim chrome - $50 (a couple of small indents, could be fixed prior to installation, could use a cleaning)
Vinyl Trim Chrome - $50 (could use a cleaning)
Rocker Panel Chrome- $60 (dirty, some pitting on the underside, some minor dents/dings expected with being on the car for 40 years)
As you can see from the pics, the edges are starting to come up on some of them. It would probably be pretty easy to glue them back down and they'd look great again.
Bayum,
The guy I bought the car from was at the swap meet, but the car shouldn't have been there (I had purchased it a week before the swap meet and picked the car up the Monday after the swap meet).
What engine, trans, rearend combo is in this? I am in Caldwell looking for a few things for my 63 Valiant convert.
