Lower radiator hose
Gr8polarbear
OHIO
72 scamp with 383. Last radiator had inlet on drivers side I moved it with new radiator to pass side. The last set up had 16 inch universal lower radiator hose. Once switching radiators I noticed the previous upper hose would be perfect for the lower if it was the right diameter. My question is in an a body with a big block what lower radiator hose are you using?
Not sure this is the exact one on my '69 with 26" B-body radiator. I'm sure it's close though.
Make sure and put the coil spring inside, there is suction there that will collapse that lower hose. Especially if using a higher volume water pump.
