Magnum Distributor / Cam Sensor only Conversion Cap
goldduster318
Overzealous Car Modifier
Lake Orion, MI
Hello All,
I created a cap to cover the top of a magnum distributor to make it into only a cam sensor. I had been using the bottom of this distributor for 10 years as the cam sensor for my EFI conversion.
Designed it up in FreeCAD and had @WaterfordMan 3D print it for me.
It has plenty of space under it for the wiring and if the cut of the distributor shaft isn't perfect.
@WaterfordMan can print more, you'd have to contact him for pricing if anyone needs one.
with parts this size, you can print them out at 100% on regular letter paper to make sure its right, I had to adjust it a little a couple of times for it to be right.
This is by far the easiest way to put a cam sensor on a small block, obviously it works as intended in a magnum application, I have coil near plug (GM LS coils) so I didn't need the rotor or the regular distributor cap. The blue wire between the outside pins is a pull-up resistor that I needed to add to get the Megasquirt 3 computer to be able to read the hall switch. These things are a dime a dozen so a super low cost item.
Hello All,
Keep the ideas coming @goldduster318 , between us I'll have a whole catalog of parts to support the A-Bodies!
